configure slot description
configure slot slot description [ slot_description | none ]
Description
Adds or removes a descriptive name to a slot.
Syntax Description
slot Specifies a specific port extender by slot number.
description Specifies naming the BPE at the designated slot.
slot_description Name for the BPE at the designated slot (max. of 64 characters long).
none Specifies removing the current name assigned to the BPE at the designated slot.
Default
N/A.
Usage Guidelines
To remove a name from a slot, use the none option.
The slot name can be up to 64 characters long.
To view a slot's name, use any of the following commands:
  • show slot {slot {detail} | detail }
  • show vpex bpe
  • show vpex bpe {slot slot_num} {statistics} {detail}
  • show vpex bpe {slot slot_num} {environment}
The following example applies the name "Accounting Dept" to the BPE at slot 100:
configure slot 100 description Accounting Dept
This command was first available in ExtremeXOS 22.5.
Platform Availability
